"Dead" batteries coming back to life?!
The only things I can think of would be corrosion etc preventing one pair of batteries making good contact and then suddenly being able to connect, or temperature related output changes. Going from 3/4 full battery life to dead in 3 weeks isn't particularly good so I'm guessing they weren't really back up to 3/4 capacity
PS. I strongly recommend rechargeable batteries
PPS. If not, I defo recommend you use a multimeter on your batteries before you throw them out as there have been some observed differences in discharge rates between the pairs of batteries
The original wireless cameras use the batteries as two sets of two - front and rear. The camera will switch between them to even out depletion over time. If one set didn't have connection, the other set would wear down. It plausible, although seemingly unlikely, that the second set could somehow have then made connection allowing the camera to start operating again.
Weird but possible.
