pinkish/redish image on arlo camera
arlo ( non pro) camera is consistently showing a red/pink image !!!!
Ho do i resolve to get back a normal image ???
Did you search? Lots of threads and solutions posted.
First, open and close the battery door to see if the reset helps. If not, open a case with support:
It's the IR filter getting stuck.
