offline and eating batteries
when i turn off my arlo camera and try to turn it on after a couple days it goes off line and stays that way. it kills the bateries when it's in off line mode. i have to replace the bateries to get it to go back online. so if i only use the camera for a day and turn it off for 2 days my batteried are dead. my camera is not under warranty any more. i would like to have it sent out for repair because there is something wrong with it. i have 4 cameras all together, if i put another one in its place and do the same thing it does not kill the batteries.. i have trouble shooted this thing till i'm blue in the face. it is a bad camera. simply put.. it needs repaired.. when i spoke to the support person she went thru the hole script.. i do not want to go thru that again.. waste of my time... she also told me no one the the earth repairs these cameras.. does anyone know who would? i find it amazing that you can't send it somewhere for repair? who makes products that can't be fixed.. if i knew that i sure woulnd't have bought 2 sets of them..
If your actually "turning off" the cameras in settings, try and just use the DISARM mode....
It uses the same amount of battery power either way. The OFF feature is more of a privacy setting if you have cameras in rooms and you SHARE. Only the primary account holder can access an off camera to allow it to be viewed.
