none of my four cameras will sync
Can't believe out of four cameras none will sync to my mobile device or my computer.
ClydeW,
What is indicating that the cameras will not sync? What is the LED behavior on the camera and base station when you attempt the sync process?
I got the Arlo Pro base station and 4 cameras and none will.synch after a verizon repair. This system is not worth it if it requires this much work. According to the base station, it is connected to the internet. Between this and charging the cameras, I should have saved my money and put that toward another system. I have tried all of the troubleshooting with absolutely no success.
You haven't given us anything to work with. What's a "Verizon repair"? WHat have you tried? What do you see?
