netgear97 WiFi password
  • 4 Replies
  • 6246 Views
Adeline190
I’m trying to connect to the WiFi- but I don’t know the netgear97 WiFi password. What password do I need to put in here??
None of the Arlo bases are accessible by any other devices other than the cameras... ( except than other arlo devices like bridge )
There are no passwords.
michaelkenward
Sensei Sensei
Sensei
netgear97 sounds like something that comes from a Netgear router.
The default password for that is on the router.
But as @TomMac says, this is not related to anything Arlo.
Just another user
Adeline190
I can’t see any password on the base unit- can you check the picture I’ve attached and see If you can see anything? Thanks
michaelkenward
Sensei Sensei
Sensei
That is a "pre-divorce" Arlo base station, when Netgear owned the Arlo brand.
As @TomMac says, there is no password that you can use to login to the wifi from that.
I am surprised that it shows the SSID netgear97.
Do you have any other Netgear hardware on your network?
Just another user
