my schedule seems not to take Day Saving Time into account
  • 2865 Views
cortjan
Since the security breach last week (I changed password and then restarted the base station) I noticed that my schedule seems not to take Day Saving Time into account. The window of activity in the planning seems to be one hour off.
Sounds familiar? How to solve?
cortjan
It took some time checking the actual situation. But the problem has been solved, as far as I can tell indeed bij restarting all systems, i.e. the base station and the camera connections to the base station. The time zone settings appeared to be correct though.
Thanks for your help, both of you.
Check your timezone setting for the base in Settings, My Devices, your base. Maybe toggle it to something else and then back. Also restart your base.
The password change doesn't have anything to do with this.
have you checked your time zone settings to verify correct ?
cortjan
