it is saying I'm not connected to the internet
  • 7 Replies
  • 3998 Views
  • 5 In Conversation
corvette02
it is saying im not connected to the internet. netgear is camera isnt
7 REPLIES 7
Be more explicit.  Are the LEDs on the base lit?  All 3?  What color? What have you tried?
Handyguy
Led is amber, arlo app is saying device not connected.
Handyguy
Recently changed from hot spot router to Hughes internet with router.
Sounds like you're not in the US.  Folks outside of the US using ISP-supplied routers have noted issues with the router's setup that had to be resolved by changing router settings or having the ISP replace with a newer model.  Do you have access to the router config?  Ports 80 (http), 443 (https) and 123 (ntp) to netgear.com must be open.
smeagal30
all light are ligted grreen
If all LEDs are green but nothing is working, I'd perform a factory reset by pressing the reset button until the LEDs flash amber. Start over and see if that helps.
smeagal30,
What device/browser are you seeing an error message on? Do you see this same behavior on a different device/browser such as the mobile app?
