Hi,
This afternoon I was unable to log on to arlo app on my mobile phone. I was at home and then realized the internet led is solid amber. So I tried to reboot my modem router and after a few minutes the green led is back and I was able to log on to the arlo app.
I noted that the server connection requires port 80,443 and 123. However, none of them are open as I tested on http://www.canyouseeme.org/.
I have a customized port (e.g. 5125) which passed the same test so it looks like the port 80,443,123 are all blocked by my isp.
However, at the most of time my arlo cameras function properly. I can log on to the app to view live stream and the motion detection works as normal.
Does anyone think the ports are really important and why my cameras can still work as normal when the ports are blocked?
Thanks,
LC
The ISP really can't block those ports since they are all widely used (80 is for http, 443 is for https and 123 is ntp for time sync). However, they could block access to netgear.com for some reason but your normal operation indicates that isn't the case.
The port test your ran is likely to test for incoming packets which the firewall should rightfully block unless you're running a server of some sort. Outgoing packets should be just fine unless you've set your router to block those for some security reason.
Thus, I think you're fine. If the system ever works, nothing is specifically blocking it.
thanks for answering my question. I understand now.
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy925
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,083
						Videos233
						Vidéo2
						Warranty & Contracts2
