initial installation failed. i am splitting off my router which is from AT&T to the arlo netgear base station. after all is hooked up i get a green light on the power led only. have checked that all connections are secure and all Ethernet cables function properly and still unable to connect. is it even doable to split my router to arlo? have searched for answers everywhere and unable to find an answer for my dilemma. any help would be greatly appreciated. thank you in advance for your time...
klm
If you mean your using a switch to give you extra ethernet ports ...yes that would work
If you having problem , you could try direct into your modem/cable device
