i want One camera NOT to record.
  • 2 Replies
  • 2764 Views
arlooo
Hi All,
I want to keep one camera basicly off unless i want to check in to live view it. How do i do this? i tried but it will not let me save when i click do nothing. i have one ArloQ and 4 Wireless units. so i would want all to record on mothin except for one, that one i would just use to check in on an area when i want to, with live view.
arlooo wrote:
Hi All,
The Q is on it's own ... re arming so we'll deal wit the 4 Arlos cams;
First you already by default have all on ( ARMED ) and all off (DISARMED).
So you need to make more MODES.
Start by reading this....https://community.netgear.com/t5/Arlo-Knowledge-Base/How-do-I-create-and-define-Modes-and-Rules/ta-p...
Then create a new MODE with all your 3 Arlo cameras EXCEPT the one you want off to live view.
AFTER you create a mode with the first camera, go back and EDIT to add the next two
* Remember that ONLY ONE mode can run at a time
* Any camera not in the running mode will be OFF
* Split the schedule time if you go thru midnight into two parts ... Up to Midnight then second half at 1201 the  next day
As an extra, you should have a mode for each combo of cameras to really control them all and any combo of same;
ARM ( all on A B C D )
DISARMED ( all off )
CAM A
CAM B
CAM C
CAM D
CAM A B
CAM A C
CAM A D
CAM B C ..... etc
arlooo
this was helpfull, thank you!
