i purchased one Arlo and would like to get another (wired) --- is that possible?
You don't give much info...
Indoors, or outdoors?
As to wired... do you mean AC power or ethernet?
There is the arlo Q camera which is ac powered or the Q+ which can be wired by ethernet and powered by same (POE, if your router supports it)
But these cams are rated for indoors only
The new PRO version can be wired for ac(inside only) or (later when released) a Solar panel to power it..this is outdoor rated
