google fiber router compatability
will this system work with my google fiber router? the network box does not have an open ethernet port.
I am not sure where I would plug it in
Not familiar with Google fiber. Are there any Ethernet ports at all for the internal network? If so, you could expand it with a switch so you can plug the base and whatever else into it. The router's port has to be internal, though, and not for the WAN.
thank you.. I talked to Google Fiber and they said I did need a switch to connect to one of the ethernet ports. I should be good to go
