disarm a sinlge camera
  • 2 Replies
  • 699 Views
k-strider
how under the new app do we now disarm a single camera? when we put washing out to dry on the patio we usually disarm that camera otherwise the wind makes the motion detectors ping constantly with the washing blowing in the wind... that option seems now to have gone? the whole mode area has gone and been replaced with a quite useless routines/modes section that is very limited
DannyBearAgain
I think all you can do is turn off the camera from the camera settings menu.
It would be an advantage to have the option to temporarily disable the camera for a settable time like the mute notification option so you don't forget to turn the camera back on.
BrookeN
You can go into your app and then under devices click on the little gear icon on the camera you are wanting to disarm. And toggle the slider to off, it will disable the camera until you toggle it back on.
