- 2
The settings are changable in Android... I know it take a bit longer for ios due to their approval setup.
You could check and add here if not found ; https://community.netgear.com/t5/Idea-Exchange/idb-p/arlo-idea-exchange
Just switched to iPhone, and surprised to find that the Arlo app does not offer customized notification sounds. So I have to look at every sound to see what it is ( or ignore it altogether - which defeats the purpose of the cameras ) . I then find here that Netgear has been promising for almost a year (in this thread alone- perhaps longer, as one user indicated) to include this feature in an update "coming soon". Still, no joy. Makes me wonder if I wasted nearly hundreds of dollars on a product that isn't supported by its manufacturer.
Very disappointed in Netgear.
oxymoronic,
The Arlo team is still working hard to deliver new features to all existing Arlo product lines. I encourage you to continue offering your support for new ideas within the Arlo Idea Exchange by adding Kudos.
Would be great
Any update from Netgear on this very important feature? seems it has been asked for very long time
I can read that this is OK on andriod, but when is it coming for IOS.
stuttis
when will change notification sounds be available for ios?
last mention is nearly 10months old
My expectation is that this will never happen for iOS. Ever. I've been a software engineer for 38 years, and when a simple feature like sound changes doesn't happen for years, the usual reason is that the code was written a long time ago, and it's unmaintainable, and the guy who wrote it is not with the company anymore, and nobody dares touch the code because they don't know what else will break. Go on, prove me wrong. But this is why I believe such a simple new "feature" (which is already present in the Android version) will not appear in the iOS version.
No and I would suspect it's not possible since it's at the phone level, not inside the app.
Is there an official response to this from Arlo? I understand it was added for Android in the beginning of the year but they also said it was coming to ios "soon." How much longer do we have to wait or should we just stop waiting?
This thread is marked solved, it is for android but it’s not for iOS. Use the new idea thread please.
you wrote : 'coming soon for iOS' on 2017-02-27 02:04 PM :
any news ?
I’m so disappointed I can’t not receive sound notifications because I have an iPhone. Nearly 3hours after the fact , I noticed one of my cameras recorded motion. Someone was hiding along side my car in the driveway. I do sit my phone down when I’m at work and home, and there is no way for real time notifications. I have 6 useless cameras. I don’t see what’s the purpose if I can be alerted when something is happening.
There's no issue for sound when a push notification happens. This thread is for a DIFFERENT sound which is possible for Android but not yet for iOS.
If you're not getting notification sounds, check your settings for both the app and phone. Perhaps reinstalling the app would help. Be sure to accept all permissions.
How do I set a different (unique) notification sound for each of my two cameras? I'm getting a pushed notification fro motion detected, but I don't know which camera is detecting the motion, because the notification sounds are the same.
Is there a way to set a unique notification sound alert for each camera?
- similar setup as Arlo
- does everything that Arlo does
- ability to change the notification sound
thanks
- 2
