cant turn off mute notification series
@AHAB31 wrote:
How do I remove this random recurring "mute" series that somehow has been set up and I have to remember daily "unmute" manually .... any ideas?
AFAIK, there is no way to schedule muting of notifications in the app. Are you saying that you see this message even though you did not previously mute the notifications?
That's right... I have to manually turn off the "mute notifications" setting every day... it's got a random time setting for the muted period as per image attached previously .
Not something I've seen on my own system.
Do you have any automations set up?
Do you use any third-party integration (IFTTT, Homekit, etc)?
Hi, thanks for responding. I don't have any automations that I know off (how do I check?) nor 3rd party integrations. It's the basic set up
What happens is each night I have to remember to go in and manually "mute notifications" and it somehow resets itself every day to mute notifications for a period of time, typically overnight.
Very Weird.
I don't understand this bit.
Are you saying that you manually mute the notifications at night? If so, how long are you choosing to mute them for?
