After resetting the system, now I cannot restart it.
Was it a full reset or power button/in sw reboot ? Do you mean sync the cameras?
Anyway, turn the Base off and then on ...see if it comes back. the first two leds on left must be on, quickly push base sync button then a couple secs later the camera sync button ( don't hold )
If not, power cycle your Modem, router and base again in theat order ...let each one come back on before the next.
After this, if the base still doesn't come come back do a full reset of the base holding in the reset for about ten secs till the front leds flash.
Then re sync the cameras as if new
