cant locate base
I set up my Arlo wireless camera, had no problem with the set upor even when I had to sync both camereas that came with it., Then went to Play store, down loaded the Arlo app, opened it, clicked on my camera "Arlo wire free camera" , clicked new user, took me to set up (even tho done) clicked next then it went into search mode to find my base. NOW THE TROUBLE, says it can not locate! Ive tried this over and over again,(10 times) nothing! I even reset the base, uninstalled my app and reinstalled it again.... I can not get it to work now.....Need help...
My sons mother gave this to me, because she had the same problem and no one would help her to fix it......If you ask me, its junk!
WHY can it NOT find my base? anyone know how to get this to work.......
Because you're now a user with an installed system. Simply log in and go with the flow.
