can you have 2 base station and 2 cams each in 2 different States
  • 2934 Views
Cycle
can you have 2 base station and 2 cams each in 2 different States and still use the same arlo app and same android???
Streak2
Master Master
Yes you can. You will use two different email accounts.
You just then need to make use of the grant access feature to allow access to the cameras across the two bases/email accounts.
There's only 4 cameras so no need for a second account. Just add the second base and sync the 3rd and 4th camera to it.
Streak2
Master Master
jguerdat is 100% correct assuming you will be setting them up in both locations using your account details or setting them all up in the one location then moving the second base and cameras to the 2nd location. During setup your mobile device/computer needs to be on the same network as the Router.
If you are setting up at your location and someone else is setting up at the 2nd location using a different account then you can make use of the grant access method mentioned. That would also apply if you went above 5 cameras and did not want to pay any monthly fees.
