camera seems dead
  • 2 Replies
  • 19351 Views
ybengui
Hi, I baughte my cameras yesterday, and during the night, started probably to do an update witch appartently went wrong. cause now, the camera is not showing any led light, i can keep trying opening and closing it, the camera do not show any sign of life.
do you guys think it's dead ? is there a way to reset completly the camera ?
Best,
Showguy
Virtuoso
Virtuoso
Once the camera is synced to the base you will not see any LED indicator lights on the camera. You only see lights on the camera during syncs and software updates.  Are the 3 lights on the base lit?
ChristineT
Hello Ybebgui,
Check out this thread that has a solution that is likely what you are experiencing:
https://community.netgear.com/t5/Troubleshooting/Camera-off-line/m-p/1612/thread-id/500#M1378
If this doesn't resolve the issue contact our support center for possible RMA.
Thank you for your post!
Christine
Arlo Team
____
Please click KUDOS or REPLY if you found this helpful.
