camera: experiencing "lens distortion." street appears convexed rather than flat.
can this be corrected?
thanks. magoo
Nope. They are very wide angle, relatively simple lenses that are basically fisheyes. You can correct in software but otherwise you'd need to add a corrective lens on the outside.
