camera has red tint
Hi
Camera has red/pint tint. I have replaced batteries but no different. Do I remove the camera and reinstall or is camera itself at fault. Thanks for any replies. Lyn
It's a hardware problem. Open a case with support.
If you pulled the batteries and reset the camera , then it continued... the camera prob is at fault.
Contact Netgear Support.
