Hello, we have an alarm system and arlo cameras so i was wondering if it is possible that we can connect camera to alarm, when alarm is activated the cameras starting to film?
Thank you for the answers
No....
mm1233,
As TomMac says above, it may not be possible...but depending on the alarm you are using, you might be able to set up or use an existing IFTTT recipe to achieve this.
Take a look at the Arlo IFTTT channel here: Arlo IFTTT
Probably a cam where recording is sound activated would be best if above suggestion doesn't work
