battery replacement
I have a battery that appears to be bad. The Arlo system is just about 18 months old. Just to make sure it wasn't a bad charger, I just bought the separate charger that charges up to 2 arlo Pro batteries. When I put it in I don't get an amber light. When I use a good battery I have the amber light and it is charging. How do I go about getting it replaced?
Jeff
Warranty for any Arlo component is 1 year. Since it's 18 months old, you're out of warranty and would need to buy a new battery.
Sounds like poor quality. Guess I can probably send the dual charger back since it was really a faulty battery.
No extreme temps. I live in NY. They are not in the Sun with the exception of the morning.
try to follow this ...
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
