battery low-email
so where IS the setting to get emails when the batteries are low? can't find it. thanks!
toptech wrote:so where IS the setting to get emails when the batteries are low? can't find it. thanks!
That's been removed. It's now a standard feature, but supposedly defunct currently. But: "they're working on it..."
A fix was deployed for this feature and the functionality should be back and working as designed. It is enabled by default, there is no longer a toggle to turn it on and off.
