batteries
My batteries went dead in least than a month,can i get new batteries under warr
I live in the Alps. My brake pads need replaced after only six months. Can I get new brake pads under warranty?
SCNR.
Ok, sorry for the above. Having a bit of fun.
The offical use-case scenario of the Arlo cameras is one four-minute clip per day per camera. A fresh battery set should last four to six months with that usage. If you exceeded that, your batteries won't last as long.
One other thing that can degrade battery life quicker is if the Wifi-signal strength at a camera's location is weak, as the camera has to work harder to maintain a good connection.
