base wont blink green for 4th camera
have connected three cameras. BAse station will not blink green to connect the 4th. Any ideas?
You may need to start over after a factory reset. Press the reset button on the base until the LEDs flash amber. Go into Settings, My Devices and remove all devices. Go back to the Camera tab and use the Add Device button to add the base and the to sync the cameras. Hopefully that's all you need.
SteveSloane,
Did a factory reset solve the issue? Please let us know.
