  • 24737 Views
patbrust
I have three cameras. Base has three lights all have been green. Now one light is blinking yellow, and all cameras are working.
When the base station has an update pending for base or camera it will flash... ( you didn't say which light ...and it makes a diff )
Go to SETTINGS, BASE STATION SETTING... make sure the AUTO UPDATE SW is toggled ON, Hit RESTART
patbrust
thank you! Looking at the base station, the far right light is blinking yellow. It stopped, but is blinking again.
if its the far right light, it may be a cam update needed... You have to open the battery door on camera and let it restart to do an auto update ( make sure auto update switch is toggled on )
check for firmware versions;
cam sw should be 1.2.2222
base is 1.3.2261
