base station wireless default password
  • 5 Replies
  • 23084 Views
  • 5 Likes
JMCONDE
Since the basestation is an N wirelss access point you can connect to it. What is the default password to connect to it? Also what is the degault IP addess ro get to cnfiguration screen if we want to change that password for security reasons?
5 REPLIES 5
Not possible at this time. Maybe if someone hacks it but that's not for this forum.
GordoCHS
I just bought a new system. Router asks for a password. None is provided. Spent 33 minutes on hold - no live agent. Only recordings that do now answer the question.
question: what is e default factory password?
GK
Charleston.
Router or base station? The setup requires your email address and password which is totally different from the router password. Should be very obvious which is which.
Kaysue44
So where does one find this password? I need one to hook to Netgear for the app. Help please
Sorry, you're not clear as to what you're trying to connect to. There is no password for the base station - don't even bother. For the router, it's whatever you set it to be (please say you changed it from the default).
