base VMB4500 blinking amber light
base VMB4500 blinking amber light, yet it says it is online, if I reset it do I have to take my arlo pro 4 and pro 5 down to reset? they are up where I can reach them. I have restarted the base and it turns green but right back to amber. this started when I tried to add one of my old pro 2 camera.
A blinking LED may indicate a camera is having issues with its connection.
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
That said, yesterday I noticed one of my hubs blinking amber for longer than I expected so I power cycled the hub. That fixed it. Not sure why I had to do that.
