arlo Pro station storage without internet??
i got a arlo pro set & 2 arlo
how can i setup to storage in arlo pro station without internet access??
Don't believe you can.... Tho once setup IF internet is lost, the base will record to the usb drive.
So the only thing I can suggest is to hook into the internet and then install the usb drive then disconnect internet. Not sure if the base looses power if the usb drive will continue to operate when it comes back, but IMO it should.
Also remember, you must 'eject' the usb drive as normal before removal to view the files locally.
