everytime i get a notification for movement i click on it and it takes me straight to the live camera. it used to take me to the specific recording of the movement
then when i click on the light widget to turn it on, it takes me to the feeds screen instead of turning the light on
a lot of times when exiting the app i still hear the camera live in my phone background. it doesnt actually close it
the app is subpar compared to your competitors. i will not be buying anymore arlo cameras
Hi @yiannit
The Arlo development team is currently investigating this light widget behavior. We will provide an update as soon as we have more information to share with the community.
Regarding your feedback on the notification redirect symptom, this is by design. When selecting the notification as it populates, you will be routed to the live stream before the recording is finalized in your Library/Feed.
Hi @yiannit
Which version of the arlo app are you using, the latest version is 5.0
Also, is this occurring with an iOS or android device?
Yes the newest version on Android
Hi @yiannit
I was able to replicate a few of these symptoms. I notified the team and they will break up the issues reported and investigate each. I will provide more info as soon as possible.
The Arlo development team is currently investigating reports of this behavior. We will provide an update as soon as we have more information to share with the community.
Ok thanks
Hi @yiannit
What about the issue with the camera staying on even though I'm out of the app.
That symptom is being worked on from the dev team, you can follow that thread here: https://community.arlo.com/t5/Arlo-Secure/Android-app-not-ending-video-streams-when-minimized/m-p/19...
So if I wait a while before clicking on the notification it'll take me to the recording?
When the cloud is done processing the date it will land in your library/feed and take you to the recording.
