I have two modes set up already. For the sake of discussion, it will be mode A and mode B. Mode A has all cameras on my account utilized. Mode B does not have all cameras utilized.
In mode A, the "add rule" option is not available. I assume this is because all cams are utilized.
In mode B, the "add rule" option is avalable. I assume this is because there is a cam on the account that is not utilized in mode B.
In mode B, since the "add rule" option is available I can repeatedly add rules. Such as, having one cam trigger two other to record video at the same time. But, I cant do this in mode A.
I removed a cam from mode A and reinstalled it in hopes that the "add rule" option in mode A will appear. It did not work.
How do I get the "add rule"option to appear in mode A? In addition to what mode A already does, I want to add additional rules to make some of the cams motion detection record on two cams at the same time. I need to get the "add rule" option to appear in mode A.
First you don't say it , but try not to modify the default ARMED and DISARMED modes if possible..
In your case where A isn't working properly ( and I don't know why ), the best thing I can think of is to make a NEW MODE "C" using the same setup as A with your same settings and then add the additional rules you want.
After you create C and all is functional, you have a choice to leave A as is or delete it.
( the other method would prob require a full reset of the base to start over as new... more trouble than making new mode )
Thanks for the reply. I was thinking before I checked back here and sure enough my thoughts were correct and you have confirmed it. I had been trying to modify the default "armed" mode. I'll just create a new mode as you suggest and go from there.
