I have a brand new system with 3 cameras, when the camera on the driveway detects motion the camera in the back yard records instead? I have reset the base and moved it's location to a high point. Other 2 cameras work as they should.
Use REMOVE DEVICE on the trouble cam and then bring it back as new.
( you may have to do both the sense cam and the one it records on )
Removed and re-added both cameras, seems to be working now. Thank you for the help it is much appeciated!
