In the basic set up I can find the serial number under the select base station screen. I then rename the device and have also left it named base station. When I hit continue is says that no base station is found with a annoying red circle with a red X inside. The light on the base also indicates that it isn't attached to an account. I've tried to connect on two different wifi systems.
Try this possible solution:
https://community.arlo.com/t5/Arlo/Base-setup-fails-VMB-3500/m-p/1676179#M63786
This did not work. Tech support said that this is a known "bug" and the fix is going to take a "indefinite" amout of time. It is pathetic that a device that will not work straight from the box is on store shelves. I was also told not to return it because they could possibly find a fix. What a joke.
We all know that it's a known issue. The work-around suggested above is your best chance. Your post says it doesn't work but then goes on to talk about tech support so it's not exactly clear what you did - tried the work-around or called support. If you did the process linked above, what were the results? What did you see? We need info as to WHY it didn't work.
