I have an older system that includes the VMB3010r2 base station and 4 x H7 cameras. I just purchased a Pro 3 Floodlight and have it pair direct to the Wi-Fi but have read if it is paired with a smart hub it can be set to continuously record.
My question is will the older style H7 camera connect to the new smart hub? Or which model hub will I need to get?
Cheers
The Smart Hubs work with all older cams including the original wire free. For the CVR recording you do need a Subscription for that that is different from the Smart Subscription. The VMB4540 is a good option.
What is the difference between each Arlo SmartHub and base station?
