Will new camera work with existing hub
  • 1 Reply
  • 196 Views
tomoljo3
I have pro 2 2k cameras and i think one is going bad. I put a new battery in it s few months ago and it worked fine for a while but now the new battery won’t charge. That was the same problem i had before. So i think the camera might be bad. Can i use any camera existing hub?
The Pro 2 is 1080p, not 2K.  Are you certain about the model?
Yes for the Pro 2.  The compatibility list is here:
Replacing the hub won't fix this, so I am a bit puzzled.
