Wifi blocker
  • 5 Replies
  • 5517 Views
miroH
Can Arlo be impaired by wifi blocker?
5 REPLIES 5
steve_t
Master Master
Arlo and Arlo Pro work on a private 2.4GHz network so I would suggest the answer would be yes. You'd need a wired system if you were worried about this
miroH
Thank you. It would have been nice for Arlo to have a local sd card on camera itself for an alternative. Just a suggestion to the Arlo team.
FWIW, the Q and Go cameras have built-in micro SD card slots.
miroH
I apologize, I was referring to the Arlo and Arlo pro home security system.
steve_t
Master Master
If you pop that suggestion into the Idea Exchange section, the Netgear Arlo team will have a look at it and the logistics of doing so
