Why does this adobe flash player notice appear when i open a camera
  • 4 Replies
  • 2986 Views
radiopunk0
How can i remove this from my camera screens when i try to viewScreenshot_2019-11-12 Arlo Web Portal Smart Home Security.png
michaelkenward
Sensei Sensei
Sensei
We won't be able to see your picture until a moderator approves it.
My guess is that it is something about a message asking you to update Flash. This is a false alarm. It is down to your browser and its interaction with Flash.
How you respond depends on that browser. In Firefox, for example, it is a simple icon click:
Click that and "allow Flash".
There is a similar move in Chrome
Just another user
You can of course allow Adobe Flash to store on the local PC.
You can also switch browsers (Chome and Edge won't give you that particular warning).
michaelkenward
Sensei Sensei
Sensei
Only if configured to do so.
Chrome throws me a similar message. I have to click the bit next to the address slot:
Chrome flashChrome flash
then "Allow flash".
Same behaviour here with Edge.
Just another user
Chrome throws me a similar message. ...
@radiopunk0's error message is not the same as the one in Chrome/Edge that you are referring to.  It isn't asking him to allow flash for the web site.  He's gotten past that.  It's asking him whether he will allow the Adobe Flash Plugin access to local storage on his PC.  Chrome and Edge won't generate that particular message for my.arlo.com (as I said in my earlier post).  At least I've never seen it in those browsers.
