Which calendar is used in the arlo app for Android?
June 2023 is missing 29th and 30th in calendar. Hence there's no recordings for these two dates. Perhaps the calendar system is not using Gregorian within the app?
Typically, if you can't select a date in the calendar to view videos, that means there are no videos to view, not the other way around.
