Which Wire free Arli for 1 hour streaming?
Hi
We have a bat roost in our roof space, and am looking for a battery powered camera that I can put on the window sill for an hour or two at dusk to do an exit count!
Can anyone advise whether any of the Arlo cameras would be suitable for this use?
Thanks 🙂
Thanks 🙂
Crank the sensitivity up to capture all movement and you should be good as long as the camera is close enough and has motion across the FOV and not directly at or away from the camera. It won't record continuously, only on motion.
