What drill bit to use to mount the outdoor mount
  • 1 Reply
  • 9906 Views
jkj22908
Been on the phone for 15 minutes.  Bought the indoor/outdoor mount which included zero instructions.
All I need is the drillbit to use to mount this stupid thing and not a single person in their support knows.
What has everyone else used?  I need to install the plastic anchors.
If you need to install plastic anchors...
PUT the base of mount in the place you like, mark with a pencil / pen the mount hole locations.
You need a drill bit just  very slightly smaller than the biggest diameter of the shaft of the anchors.
You drill the hole, use a small hammer to pound the anchor flush to the level of the materal you drilled into ( or a normal hammer used lightly )
Place mount on top and use screw into anchors
i do recommend a temp mount first to insure location is good before permanent mount hole by duc tape or however.
