Vmc3030
I have three cameras set up at the exterior and 1 in my garage. This system has been driving me crazy for 4 to 5 years now, the cameras go off-line and out of sync sometimes just out of sync and the only way to get the cameras working again is to take them down and re-sync them this happens every day and every day is a different camera. I have tried to relocate the cameras, batteries full charge that doesn’t work, restarting the base station does not work. Can anybody help me with this problem before I throw the damn things out
I would remove each camera using the app.
The reset the base https://kb.arlo.com/1057976/How-can-I-reset-my-Arlo-SmartHub-or-base-station-to-the-default-values
and the set up from scratch
https://kb.arlo.com/987/How-do-I-set-up-and-sync-my-Arlo-wire-free-cameras
In addition, it may just be the location of the cameras relative to the base. Move the base as far away from the router as possible. What are the WiFi icons showing for each camera? Maybe you need a second base so some cameras connect to each base, providing them with optimal signal.
