Vmb5000 Base station
Hay anyone know how to get the base station to connect to 2nd gen essential cams. I have a mesh set up can’t get it to connect. The base station is from 2019 but should still connect ? Thanks yall
Which base is it? Look at the bottom for a label that shows VMBxxxx. Is the base active in your account and has the latest firmware? Your mesh network has nothing to do with connecting to a base. The base connects to your router (or a satellite) via the Ethernet cable and provides its own separate WiFi network for the cameras.
