I have 5 cameras. I was able to get them all except one reconnected after not being in use for 6 months. I have tried multiple times to snyc it. I deleted it from the app. And I get slow blink blue to rapid blink Amber. After about 10 times it just stays at slow blink blue.
Pull battery to reset camera, reinstall
reboot the base using the power button, give it time to come back online ( 2 mins )
quick press on base sync button, then camera
If NG repeat.
After several attemps, try and move the base as far away from the router as the cable allows, try again
Some have stated in the past they unplugged the ethernet cable and then it works but no reason this should... but easy to try
If still NG, contact netgear Support at bottom of page for possible warranty
