Viewing Arlo cameras on iOS 11.1
Does anyone know if the latest Apple IOS 11.1 upgrade affects how I view my cameras on my phone! Sometimes theses updates are not compatable with arlo
MPooh-1,
Are you experiencing an issue viewing cameras? What are you seeing that indicates there is a problem?
So I just don't do the IOS iPhone updates! I'd rather be able to watch my house/cameras.
Ipdb644,
Are you getting an error when attempting to live stream? What are you experiencing that indicates an issue?
Do you see different behavior when using a different device?
Works fine on WiFi.
Arlo app version 2.4.5.
iPhone version 11.2
Completed network reset
Confirmed cellular data enabled
All other apps connect to internet.
Have uninstalled and reinstalled app
Hard reset on iPhone
Another iPhone connects fine via the app to same base.
Rmaar,
If another iPhone is working with the same information, this isolates the issue to that specific iPhone. At what point when using the app do you get the error?
Same here, I just bought an iphone x, and Arlo tech said use a different phone to set up. Cuz they dont have any resolution to the ios updates yet , very convinient for them to say that. !@#&. Mine cant be set up, so i'm stuck!
Rbroldan0507,
The Arlo mobile app is compatible with the iPhone X. What issue are you experiencing? Can you provide us with some more details?
The latest version of the app is crashing on my iPhone as well. I can use it on my iPad but not the phone. It immediately crashes when you open the app. I deleted, redownloaded and it works the first time you open the app. When you go back to open it again, it crashes. endless loop of crashes. Update 2.5.1 seems to have an issue, at least with some iPhones.
jjtollus,
What model iOS device do you have and what version of iOS is it running?
iPhone X running 11.3.1 and Arlo version 2.5.1
I have to use an old iphone, it connects , but i dont hear sound from the of the cam. Now how do i fix that.
A new version of the iOS app was released to the app store. Please make sure you have the latest version installed and let me know if you still experience this issue.
Release Notes - iOS App 2.5.3 - 7th June 2018
