Vertical lines appearing on video
Purchased a 4-pk two days ago. Installed cameras the same day. Moved the camera covering front porch to a new location today. After completing the installation, vertical lines began showing on the video. Still shot included below. Tried removing the device and then re-syncing. Same issue. Completely reset the entire system, including the base unit. Synced all cameras again. Same issue. Tried switching batteries between units. Same issue. Day is cloudy and raining so no direct sunlight shining into the camera. Anybody else experience this issue?
Try and switch two of the cameras to see if the problem follows the camera giving you trouble... if it does, contact Netgear support as it may be defective
If it's not a poor wifi signal, it'll be a faulty camera
salaniz,
Please contact the Arlo Support Team to further investigate this issue. You will find several options for contacting support in the provided link. If you have any additional questions/concerns feel free to private message me. I would be happy to help.
