Just purchased the Arlo 3 wire-free cameras. The base did not connect to the internet. I followed all the instructions. I even called tech support. I was told to box it up and return it for another one. after 2 hours, I exchanged it for another one and still cannot get my base to connect to the internet. switched Cat 5 wires, they all work with the other components. Returning for a full refund and trying another product. I even opened up my router via online log-in and no issues there. There is no on/off switch on the base. just a sync and a reset pinhole. Tried that too and did not work. I researched for 4 hours via Arlo website and troubleshooting info. Such a shame, it looked like a good product. Off to another brand.
I finally got it to work. The issue is that our internet provider uses Proxies. I logged into the router and change the proxy info. A big thanks to my IT person who helped me. So after so many days of troubleshooting, it seems that the issue is the internet provider. So before you get frustrated, i suggest you talk to your provider and let them know. If you can log into your router, its even better.
We probably could have helped but too late. Good luck.
I have not had the time to take it back. Do you think you can still assist? I even tried contacting my internet provider with no luck.
Until the Internet LED goes green, nothing will work. The base is connected to the router but not to the servers. If the ISP owns the router they are the ones that have to fix it. If you own the router, we may be able to help.
I am currently in contact with my provider. My brother in law just purchased the same ones and he lives in a nearby town and the same issue. I am upgrading my router to see if that helps. If not, its back to the drawing board with the provider.
I do have online access to the router. Is it possible to change some settings? I am IT savvy but not a pro. I tried logging in and viewing some parameters but not sure what could help. the Modem/Router is a 4 port SURFboard SBG6580
It's hard to say but download the manual and check out settings starting on page 54. It has nothing to do with wireless since the base connects via Ethernet. Look at IP, MAC and port filtering to see if anything is set. If so, turn it off unless you know of a specific reason not to. You could also see if you can read the router logs, looking for something that relates to the base MAC address (maybe reboot the base to force attempts to connect).
A slim chance that might help would be to reboot the modem/router and base, in that order.
Just because other devices work doesn't rule anything out. The ISP has been an issue in the past and they can eventually figure it out. Who is the ISP?
						Accessories4
						Activity Zones1
						Amazon Alexa1
						Apple HomeKit2
						Apple TV App9
						Applications mobile et en ligne1
						Apps4
						Arlo Go3
						Arlo Mobile App722
						Arlo Pro36
						Arlo Pro 21
						Arlo Q (Plus)3
						Arlo Smart196
						Arlo Web and Mobile Apps18
						Arlo Wire-Free30
						base station1
						Batteries529
						Before You Buy927
						Can't view cameras live at all1
						Dépannage1
						Détection de mouvements1
						Features1,070
						Fehlerbehebung1
						Firmware Release Notes93
						Google Assistant1
						Hardware1
						home security1
						IFTTT (If This Then That)105
						Installation2,046
						Iphone 14 pro1
						Live view1
						Modes and Rules1
						Motion Detection2
						Object Recognition3
						Online and Mobile Apps983
						Online und mobile Apps1
						Order Not Going Through... help please!1
						Other Discussions1
						Partner Integrations4
						Security1
						Service and Storage14
						Smart Subscription3
						SmartThings71
						Troubleshooting9,082
						Videos233
						Vidéo2
						Warranty & Contracts2
