VMS3330C I can only see live mode, it won't record when it detects motion
  • 1 Reply
  • 1935 Views
mwynne01
I can see live mode, and it had one recording from when I FIRST was messing with them, but no recordings after that.
Are the running men for each camera in the Devices tab black or gray? Gray means disarmed so no recordings will happen. Use the Mode tab, click on you base and verify that the Armed mode is selected. You may also need to increase sensitivity for each camera, depending on where it's mounted and what it's monitoring.
