VMS3230C I can not get my cmeras set
  • 1 Reply
  • 2244 Views
WEM1942
Kind of terse in your description for help.....
But, first ,what are the LEDs on the base showing..... The first three from left ( or at least the first two ) should be green.
If the first two are green, quick press on the base sync button and then the camera sync button should get the camera connected.
If the second led is amber, you do not have an Internet connection which is required
