I purchased this because it had a Netgear "base station"; I wanted to avoid a "router" hookup.
I need a router???? I just want to hook up the system to my PC.
Shall I return it??
You can not just hook it to your PC....the base needs an Ethernet port to access the Internet.
usu the port is off your router/ wifi unit.
As to returning it.... You can give a friend a gift. 😀
